Isolated gate drivers sounds like a Good Idea if 4-20A is being switched. There’s pretty much no reason ever to not use a multi-layer board these days, but a multilayer board in itself does not guarantee you won’t have signal integrity, noise, or EMI issues; you will have to pay close attention to current paths.
Great thought and if this is implemented in the STM as @LukeBeno pointed out I could maybe use JTAG and dasy chain them. But It sound mor stable using RS485 or standard UART…
I must say I’m most great full for all response this have propelled my thoughts so much further.
@LukeBeno as you both has pointed to there is much I have left out. So I will explain some more. There is no need to stream the data all data just need to be stored for the last 8 seconds (would work with less but 2-8 would be nice). Then when the system is stopped due to external instruction or internally the system can fetch data from each individual RAM when i’ts needed to inspect what did happen and be able to scroll through. So the buss speed will need to be about 500kbit/s. So the buss will not need to be to fast.
My constraint is:
*Space is a constraint since I would like to fit the complete system in a box which is about 550x450x200mm.
*Signal integrity is of great importance since one the signal switched are measured by other systems.
*Robustness of the system and downstream systems. So the dynamic watch of the current and voltage is to
ensure no damage to the SSR and the connected systems.
*Logging of as much data as possible to ensure no need for rerun to understand why things happened.
Budget…as always that is a factor.
This is not how I ment as I thought I would use two ICs to drive a driver I would use driver side low and high. So that if both ICs (current and voltage) would agree that all is fine the relay remains open but as soon as one decide that is not ok that IC just switch the pin and the SSR closes.
Great I think that would shave of about 50% of the SSR cost, but that would increase the space need. So many tough decisions.
That one seems perfect. I will look in to using an F3 or F4. 4 ADC at 5Msps is crazy. And The cost would be about 40% lower per Msps but the logistics of using only one Memory would be nice. The only problem I see with that solution is that the largest 3.3V compatible RAM I have seen is only 512Mbit. The higher ones is lower voltage… I could use two and do multidrop on the dress pins and feed two memorychips.
Oh, hmmm, a bunch of MCU’s now have comparators as well as ADC’s, so that you could probably implement high and low-side checks within the same MCU and have it inhibit the channel as soon as a comparactor tripped.
STM32G4 also seems like a more modern alternative to F3. Also probably has multiple IO power domains to interface to lower voltage memories as well as 3.3V analog.
Isn’t an SSR already isolated from the contacts?
Seems like you can keep everything lowside referenced with the proper current sense circuit.
That would improve the protection level even more. That though did give me one more thing to solve. How fast is fast enough for a protection circuit. The HAL sensor for current is 1Mhz so that is why I aimed for 1Msps since the low cost MCUs seem to be in the same region for the ADC ample speed.
Nice! Will look in to that definitely!
Yes they are. I will use the optoiso. gate driver if I use MOSFETs since they would need them.
I will use a 1Mhz Hal sensor which outputs a voltage.
This depends entirely on how easily your load(s) will release their magic smoke. Some loads can withstand substantial overcurrent with only a bit of heating; others will vaporize in microseconds. Without knowing what you’re monitoring/controlling, it’s difficult to comment.
I don’t know what I will be monitoring since this will be a generic product which will be used for all kind of systems. So it could be ADCs, FPGAs, resistors, caps, Opamps and so on. So that question is more of a what is good in general. Normally my gut feeling is like 1 ms, but that is just based on some data sheets I have read in the past not any solid industry standard… But I totally understand your point! Don’t get me wrong.
Well, on processors that I know of, the comparator would fire off an interrupt, so the response time would almost always be faster than reading the ADC result and acting on it. You just have to ensure that you are not masking the interrupt with a long running ISR.
Some devices have comparator output pins which you could use to drive a latch that shuts down the relay with hardware so that it would be instantaneous. You might need to filter the response, actually, so that you can tolerate glitches.
If it was only DC, I’d suggest looking into some “SmartFET” type products as an alternative to SSRs. They’re available in high-voltage and high-current models, include overcurrent and thermal protection, are logic-level controlled, and often have current monitoring outputs (albeit not usually very accurate).
Interesting thoughts. I will keep that in mind when i decide on a chip to go with. Thanks!
Oh that is a nice part that I have not heard about. Seams like a good pick when dealing with only DC. Sadly that is not my benefit since I don’t know now what type of signal will go where or rather I don’t want to think about what signal goes where. But for driving solenoids and similar loads that would be great. Thank you for all feedback!
I’d like to pop in for just a sec and hopefully avoid you some future headaches - if you’re actually intending on using S D RAM, you should note that DRAM variants require very different controllers than simpler SRAM types. Don’t expect to be able to just spit data onto its DQ pins and run the address lines naively. You’ll need a controller of sorts, and that controller will probably have to have some buffering/caching if you intend to have a rolling buffer (DRAMs require periodic refreshes, during which they can’t be used). Sounds like a fun and challenging project!
Julia,
Do you have your favorites? I’m currently in the market for using smaller smart FET’s (< 1 amp)
The only one I’ve ever designed into anything is this 70A bad boy:
It’s proven to be pretty darned bulletproof.
Oh that is great info! Saved me a month or two of headache. I will now go down the road of a single STM32F3 chip with 4 ADC at 5Msps and use scan mode to cover 8 SSRs (2 ADC measurements, current and voltage per SSR).
Hrm, not sure? What was the context or the timestamp?
This weeks episode at about 1:04:00 … or maybe it was a different discussion about relatively the same topic
