Help me identify this connector
Hi!
I would like to inquire information about the type of connector used in the I/O port. Could you provide me with the model number of this connector. Its mounted on DRTS64 automatic relay test set.
Thank you!
Snimka zaslona 2024-09-24 101948|638x500
Search for military circular connectors on Google. I believe that will help you find the right connector. They find in different sizes/pin count.
Appears to be CX30-32 aviation circular connector:
https://www.micros.com.pl/en/product/z-cx30-32,121896.html
or possibly YP28-32:
https://www.walmart.com/ip/Aviation-Connector-28mm-32P-YP28-32-5A-Waterproof-Male-Wire-Panel-Power/863568614
You will need to do additional checks on size and shell shapes.
In your device, it seems like the female socket is chassis-mounted, which is I think less common. Here is one example that seems like the same:
BTW, while looking around, I learned that these connectors can incorporate integrated EMI/EMP filtering! MIL-DTL-38999 Series I, II, III, IV Cylindrical Connectors - Page 8
MIL-DTL-38999 Series I, II, III, IV Cylindrical Connectors - Page 10
Thank you so much for your time. Unfortunately, the main problem I have with finding the same connector is the “notch” on the connector. I added a photo of the cable that is supposed to connect the connector on the photo and the one I’m looking for (idealy the same model).
Kabal|687x500
Also - please do not spam the forum by posting the same question multiple times:
