USB-C Soldering Iron (TS80P vs HS-01) : Recommendations
Hi all
I am looking at a portable soldering iron and it seems there are two leading contenders - the TS80P and the HS-01. Wondering if anyone has any solid experience they can lend to help me decide
TS80P:
Cost 730 SEK (including 1 tip)
Replacement Tips: 449 SEK
Pros: Available locally, Field Box (Omnifixo - Field box by OMNIFIXO - Thingiverse)
Cons: 30W, limited range of tips - expensive tips
HS-01:
Cost: 600 SEK (including 6 tips)
Replacement Tips: 110 SEK
Pros: Cheaper initial purchase, more tips in the box; cheaper tips; higher power (65W)
Cons: Not available locally (import duties and tax; harder to get tips - need friends in the US to send); no field box
All in all, the HS-01 seems the much better choice, though it does concern me that it will be harder to get replacement tips. I have a friend visiting from the states soon, so I can get the unit from amazon.com (or the shipping isn’t too bad), but the tips are not available to ship (for some reason). I have no idea how long the tips will last though, maybe thats not such a big deal. Also, silly as it sounds, the field box of the HS-01 that I linked to is a very big plus - being able to carry the iron, some solder and solder base plate (https://omnifixo.com/) would suit my use case very well. I use the PCBite at home, and a small version for the field would be excellent! I guess the obvious solution is to remix the box to fix the HS-01 (make it a wee bit longer as the HS01 is longer) == more storage (a slight adjustment to the top so the omnifixo will still fit of course!) - whilst I’m at it, maybe add a second layer for the power bank (also attached by magnets)
I have two main use cases
  1. home: My workbench is in a shed where there is no permanent power; when i want to use my main solder unit I need to run an extension cable from the house. For small jobs like attaching header pins, or small, simple boards this would be my unit of choice
  2. “field” - although I don’t go out in field much, i often help friends with projects, so having an iron when i visit to troubleshoot / install / assemble etc would be beneficial
to be honest, neither of these two cases is likely to be common, but common enough right now to cause me some issues
if i look at it from that perspective, the HS-01 seems to be the clear winner… it’s the replacement tips that is the main concern…
I know Dave Jones at EEVBlog gave the HS-01 a good review and replaced his TS80P with it… and that’s normally good enough for me - but looking for an external verification; and if anyone thinks the lack of ease of sourcing replacement tips is likely to be an issue
you can also pick them up on aliexpress, they should be able to ship tips to you?
yeah, to be honest I’ve never been a fan of AliExpress - known a few too many people who got bit by non-genuine parts etc… I’m normally happy to pay the premium to buy from someone who has a reputation to uphold and will handle a support case if need be…
but yeah, that would be a way to solve the tips issues for sure
I own a TS100 and it’s a fantastic tool, honestly one of the best soldering irons I’ve used. I love it. But it became significantly better once I upgraded it to IronOS (GitHub - Ralim/IronOS: Open Source Soldering Iron firmware) so that’s something to consider.
Also, I bought it on aliexpress, and I wouldn’t worry too much about buying there. I buy plenty of stuff there and as long as you stick to reasonable sellers (e.g. sellers that have actually sold something) and offers at reasonable prices, things usually work out fine. I mean, don’t expect miracles: some things are expensive for a reason. But if you have reasonable expectations, it’s fine.
I also have a TS101 (TS100 with wider display). It is very portable, heats up quick, and I mostly like the three preset temps that just change with a button push. I don’t even have move or look up to boost the temp when needed. It is very short, which makes it easy to control for super fine work under the microscope.
Hi,
I’m not a big fan of self promoting, but at this point I’d be stupid not to mention it. I’d like to add one of my projects in your list of candidates.
A few years ago, through an employer I’ve gotten to discover the impressive Weller RT tips; and like other makers out there got inspired to make a compatible USB-powered soldering iron.
I had a design based on a STM32F0 ready to hit production right before when COVID came. Working around component shortages was no fun, really; especially on a space-constrained design. It got to a point where I gave up entirely, for a while.
I revisited the project when the RP2040 came out. It is now at the center of a second working design. Here’s a sneak peek.
What’s next then? Things will move fast in the next weeks and months as I am planning on a (small) crowd funding campaign. I will also bring some at the Hackaday Supercon 2023 in November.
Marketing is not my strength (there’s a reason I’m an engineer) but here are a few arguments supporting why I think it deserves to be considered:
  • machined and anodized aluminum enclosure,
  • uses a robust USB Type-C connector from Würth Elektronik,
  • uses probably too many decoupling capacitors,
  • protruding lips around the USB cable to relieve mechanical stress on the connector,
  • supports USB BC, QC, and PD,
  • heats up in about 3 seconds when powered by 20V 3A,
  • fully intend to opensource schematic,
  • fully intend to help with adding support for IronOS.
If you are interested in keeping up to date, you’ll find below links to Discord and the Hackaday project page where I’ll be posting updates as soon as I get the crowd funding campaign going.
Regards,
Nicolas
hey, thanks @jwr & @jhannon - that’s two votes for TS* (I would be going the TS80P in this case, rather than the TS10*)
Seems the TS80P is supported in IronOS
but i had forgotten about the Pinecil! which is pretty good pricing!
https://www.amazon.com/PINECIL-Smart-Mini-Portable-Soldering/dp/B096X6SG13
hey mate, that looks amazing; ill definitely look into it and follow progress
best of luck!
Wow this looks amazing. CNC Aluminum enclosure is an excellent touch. Looking forward to it being for sale.
Any chance that I can get a spot for one of the early units?
Thank you sincerely for the positive feedback! I am focusing my efforts towards getting the crowdfunding campaign up as soon as possible. However, if things take too long I will happily put a few early units up on sale on Tindie.
However many you’re bringing to supercon, bring more, plus one for me. You’ll sell out of them. Don’t take that as a sign of market fitness though - everything at Supercon is “ooh shiny, that’s cool!”
I’m actually quite happy with my TS100+PD-trigger and handmade silicone lead. But the connection isn’t very robust (cheap bad 5.5x2.1 plug that always works itself loose). Also, because the tip resistance is specified for 60W at 24V, it’s rather less powerful at the 20V PD provides without building in a boost converter. I actually went to that length as well, but it’s a bit inelegant to say the least.
The last two things to consider: 1) if you can find a quality silicone-insulated USB-C cable that’s good and floppy, that’d be worth almost as much as the iron. Having a power lead that tugs the iron around on the bench is no-bueno, and the thin 22ga silicone lead my own iron uses is for sure the nicest feature. 2) it’d be ideal to ground the iron’s tip to the USB-C shell through 1Mohm, so that you can modify a supply to earth-ground it for ESD purposes. So much the better if you can build and sell a supply that does just that, since everything off the shelf is fully isolated and rarely includes an earth ground prong.
I actually have a writeup from like 2 years ago on those two modifications that I did for the TS-100, but alas, I haven’t actually finished or posted it. Whoops.
Hi all,
Just wanted to quickly share that the crowdfunding campaign is finally live on Crowd Supply. I feel super excited, it’s been quite an adventure!
@alexw I took your advice on silicone jacketed USB cables, and I think I finally found a supplier. Hoping the samples turn out great. As for grounding, I was pleasantly surprised to find this CUI SDI30C-Q-UTB-CUB three-prong power supply that only delivers 30W but does not leave the ground floating.
Regards,
Nicolas
Instantly purchased, thanks for making this!
If you need USB-C power supplies, let me know, we are launching some products in this category. Ours are however only 2 prong.
I never did follow up - finally pulled the trigger and made my order a couple weeks ago. I’m excited to see how your cable selection shakes out in the end :slight_smile:
@nschurando how is the build process going?
Oh I appreciate your order @alexw, and will be happy to hear your feedback. I should receive the cables within a week, and will happily share an update then.
@LukeBeno and for anyone interested, below is the update message I’ve just published on the Discord server. Here’s a quick overview of where things stand and what’s happened since the campaign reached its goal.
:calendar: First off, I want to acknowledge that delivery is delayed — probably by a month or two. There are a few reasons for this, and I want to be fully transparent. One of the biggest factors is that the funds from Crowd Supply arrived much later than expected — late February instead of early January. That delay had a cascading effect on ordering parts and kicking off production.
:muscle: But I’ve been using the time to make sure the design is as solid as it can be before pulling the trigger. Thanks to a helpful comment from the community, I discovered that under certain conditions — specifically when the tip is hot-unplugged — the voltage intended for the heater could momentarily short with the thermocouple signal and stress the analog front-end IC well beyond its limits. It wasn’t something that showed up in normal use, but definitely something that could impact long-term reliability. So I decided to go through (hopefully) one final PCB design iteration to add proper protection circuitry.
:books: One thing that’s been keeping me really busy is certification. To help navigate the regulatory maze, I got in touch with @mayermakes — a fellow maker who’s launching a consulting company to help small hardware projects get CE certified. His input has been incredibly valuable in identifying all the applicable standards and their various requirements in terms of documentation, testing, and labeling. If you’re interested, feel free to check out smander.com and their Discord server.
:grimacing: On the sourcing side, I ran into an obstacle with the original supplier of the plastic buttons (JLC3DP), as they weren’t able to provide the necessary RoHS and REACH documentation — which is essential for that part of CE compliance. I’ve since been reaching out to alternative suppliers who can provide proper certification. I’ve identified three promising options and am currently waiting on samples.
:lady_beetle: Meanwhile, I’ve also been improving the firmware. Some USB Power Delivery sources were randomly resetting the iron. As some of you may know, USB PD is pretty strict when it comes to timing — messages need to be acknowledged in under 195µs, which the FUSB302 takes care of, but replies handled by the firmware must come within 15ms. To keep things simple and easy to maintain, I wanted to avoid pulling in any form of RTOS due to the learning curve and hidden complexities. But as features and debug code accumulated, the timing started to slip. So I refactored parts of the firmware to be more cooperative. That fixed one issue — but also exposed another: the firmware didn’t handle unexpected PD messages gracefully. I ended up improving the messaging stack to be more robust overall. It’s still not perfect, and I may revisit it again post-release, but it’s in a much better state now.
:electric_plug: Production of the silicone USB Type-C cables is complete, and they should arrive within a week. While I have the theoretical folded dimensions, I’ve been waiting to get a sample in hand before deciding whether to slightly adjust the packaging size.
:pray: Thanks so much for your continued patience and support. I know delays are never fun, but I really want to make sure you receive something reliable and thoughtfully engineered. As always, feel free to reach out if you have any questions — or just want to chat.
Regards,
Nicolas
Thanks for the update, keep up the hard work! Delays are inevitable when making something great.
Hey @nschurando, how’s the campaign going? Also, are you coming to Hackaday Supercon this year?
Hi @alexw, sorry for the belated reply. I appreciate your continued interest!
The past few months have felt like a bit of a sprint at the end of a many-years marathon :sweat_smile:. But last Friday was a pretty exciting milestone for the project! I shipped the first batch of units to Mouser (being their parent company, they handle the logistics of Crowd Supply projects).
To help me with production, in one of those “this might be overkill, but it’s going to be beautiful” moments :grin:, I built a test bench I’m actually quite proud of. If you’re curious, I wrote a bit about it in the latest project update.
I read the latest this morning with great excitement, congratulations on getting to shipment! I’m very excited to get mine :slight_smile:
As for that test jig - definitely 0% overkill - that looks like EXACTLY the right amount of effort!
Oh - and I want to know (much) more about those 4% failures!
