I have been working on this one for several months now, and I am officially stumped. This is a subset of a larger project (industrial interface boards for the Raspberry Pi), and this bug has been plaguing my progress on the greater project for quite some time.
The basic circuit design is as follows:
Circuit Diagram
Basically, the signal comes in from the field through a front end offering protection and filtering (the jumper selects either 4-20mA or 0-10V operation), and is buffered by a AD8220 Diff Amp. The output from the AD8220 goes to a MCP3424 ADC. The -5V for the AD8220 is provided by ICL7660S charge pump IC. The result is a fully isolated and well-protected industrial analog input.
For a few seconds (I will explain a second), it works. On the output of the Diff Amp, I see 1.99V at 20mA, which is about what I would expect to see given the cumulative error of my components, etc.
But, here is the issue. I only see 1.99V for a couple of seconds, and then it "discharges* down to 0V. If I move my volt meter probe to the negative side of the input, that side “discharges”, and then if I move my probe back to the output of the Diff Amp, it is back at 1.99V…just for a few seconds.
Sounds confusing, right? Here is a video showing what I just described:
YouTube Video
I have removed any component I thought would maybe cause current leaks - the TVS diode, the input zener…and, no change.
So, I am officially stumped. Oh collective wisdom of the Internet, what sayeth you?
I am leaving for a business trip, but as soon as I get to a place that I can write, I will pul together a long form response. The suspense!
