I wanted to share a little project for everyone working with AVR microcontrollers.
If you have designed a piece of hardware around an AVR microcontroller, and you need to flash say 20 of them, I did not find a really good way to do that.
Great looking project! I always find the ZIF sockets so satisfying to use.
What are you programming the chips for? A kit of some kind? I wonder if the dearth of solutions in market is because many programmers have moved to targeting on-board programming?
Usually I do just in-system-programming with the standard 6-pin header. Then I had a client project with a socketed 328 and they wanted to run their own small batch production.
Someone suggested to add the ISP header to this board so you could do both. Makes sense.
