If you don’t mind, I’d like to know more about your soldering equipment, supplies, and technique.
For example, you mention that you’re using flux: What kind and how are you applying it?
What kind of solder are you using? Composition, diameter, and core content (if any?) I ask because, for example, I’m a huge fan of 63/37 eutectic tin-lead solder for home assembly (where I don’t have to adhere to RoHS rules) and I like to use pretty narrow-gauge solder so I have good control of how much I feed in. It does look like you’ve got a bit more solder than you need on most of your joints, and you’ve also got little spires coming off, which suggests it is not wetting together and being shaped by surface tension.
What kind of iron are you using? Is it temperature controlled with a base station and thermostat, or are you using a fixed temperature iron with no controls? If it is temperature controlled, how hot are you running it? And to be clear, no judgement here: Like so many things (cameras, guns, friends…) the best soldering iron is the one you have with you, but there is a huge range of equipment available, and even at the low end a small investment can get you big returns on usability.
How are you cleaning and tinning the tip of your iron? I really like the shaved-metal ribbon cleaners over wet sponges, to not sap the temperature as much, and dippable tinning paste. And what size and shape of tip are you using? Is it clean and well tinned (shiny all around) or are there any corroded spots?
How do you clean up excess solder? I like to have solder wick in several different widths, but sometimes I also like to use a solder-sucker…
How good are your eyes, and are you using any magnification? My eyesight is terrible, so I use a head mounted magnifier for almost everything, unless it’s really small, and then I use a binocular microscope (which you can find surprisingly cheaply these days, at least compared to 15 years ago…) And if you are one of the lucky ones that doesn’t need any magnification, are you using safety glasses to keep little bits of ejecta out of your eyes?
And I know this is a lot already, but could you describe your sequence for putting down SMT components in particular, both two-lead passives and the SOICs?
And as mentioned above, some basic cleaning stuff is always good, both for shining up pads BEFORE you solder, and cleaning the flux off AFTER. Q-tips and 99% rubbing alcohol (aka isopropanol, aka isopropyl alcohol) will get you far.
