Originally published at: https://contextualelectronics.com/topic/problem-power-swap-buck-boost-layout/
It’s important to try the layout without simply following along with the CE layout videos. Most switching converters have layout advice in the datasheet. However, this one did not. Instead, it has the layout advice along with the Evaluation Module (EVM) datasheet. View the TPS63030EVM datasheet and check out the layout for suggestions on how to…
