Originally published at: https://contextualelectronics.com/topic/power-swap-v2-boost-testing/
The boost circuit worked on first try! If this is not the case for you, check that the voltage at the FB node is 1.25V. The load testing showed that the boost can deliver about 400 mA before going out of regulation. We will need to check if this is in line with expected loads…
