Originally published at: https://contextualelectronics.com/topic/power-swap-v2-boost-assembly/
The boost controller chip had some excess solder due to not using a stencil during assembly. Always double check the values of your capacitors before assembly. Testing the parts directly may save you lots of headaches later on. The input and switch nodes were at the same potential upon testing pin connectivity, but the inductor…
