Max Simmonds Build Log
Another small update - I’ve been working mainly on the ebike controller as that’s what’s taken my interest at the moment (plus moving houses means that the solder station is not setup, and the oscilloscope testers require soldering. I’m hoping to do this in the next week and get a batch ready).
Regarding the Ebike controller, I’m still capturing the schematic and scope of the controller. I’ve been looking into Ebike braking, and whether I want to incorporate regen. It seems for a bike, given the little momentum it has, regen does not give you a lot.
The BLDC controller I have chosen has a “brake” input, which apparently shorts all the low side MOSFETs of the 3 phase inverter. I’m a bit hesitant to use this as a method of braking, especially at high speeds - but I’m wondering what might happen if I PWM this pin, would it give the effect of braking without causing too much damage to the motor (1000W)? In order to speed things up, I’ll route a line to the uC to the brake line, and have a push button input on the handlebar to use if necessary, but I think I will be relying on mechanical brakes (which are required in any case, as e-braking only works when the motor is turning, unless you want to run the motor in reverse, which is another option I have).
Overall, I think I have now decided on all inputs/outputs I need, number of ADCs, I2C and SPI lines (SPI solely for the SD card, which Chris mentioned).
It’s very much in a draft state, but I thought I’d share the KiCAD schematic - I haven’t used hierarchical layout before in KiCAD, or buses, so it was fun to incorporate them here.
Hopefully in a weeks time I’ll have more to show!
ebike_controller.pdf (185.9 KB)
Another week! Man, do they come around fast. I’ve made some small progress, both with the oscilloscope tester and ebike controller.
The oscilloscope tester is slowly moving forwards - I’ve soldered a few up boards, but before I launch them on their website I’d like a good batch, just on the off chance a few people might buy them!
Therefore, I’ve ordered enough components to make 50 or so. One issue I was having was my liquid flux ‘baking’ on. I tried to remove it with IPA, and a few other things, but nothing would budge it:
Then I came across “Flux-Off” by chemtronics. And it worked wonders:
After some IPA (to remove the dull shine you can see above) it’s perfectly clean. The flux was #835 by mgchemicals, it’s a great flux but damn is it hard to move.
ebike_controller_update1.pdf (279.2 KB)
I’ve recently been working on the IO of the STM32 - usually these pins are already assigned in the projects I work on, so it’s been fun trying to see what pins have what alternate functions, and swapping them such that I can get all the functionality I want.
One thing I’d like is to measure the battery voltage and currents (and, at some point, write them to the SD card) and so I’ve been looing into that this past week. For work, I’ve been designing a ultra precise current measurement circuit. Overall accuracy isn’t an issue, but precision was paramount. So, I’m quite familiar with the types of parameters for op amps that affect current measurements. It didn’t take me long to find a cheap, but suitable current amplifier op-amp. I’ve added a filter, a decade below the motor switching frequency.
For the voltage measurement, that’s quite simply a potential divider, with another filter. I added a zenner since this is a direct connection from battery to MCU.
The next steps are to add the SD card electronics, LCD electronics, the interface to the throttle and add the connectors to the outside world, until next week!
Max
Very interesting projects
About the current measurement, it might be a good idea to go a lot further down than just a decade below the switching frequency, to make sure you are free of the motor ripple
Thanks! That’s a good point, I’ll probably go another decade. I suppose I could do the low pass filter in software, but where’s the fun in that!
Well, here we are again. I think I realised this may be in the wrong section of the forum, but I don’t know how to change it so I guess it’ll have to stay here.
I’m supposed to update this log every week, on a Wednesday, however, I’m consistently a day late so let’s just say this is new Wednesday.
I got a bunch of parts arrive 2 days ago for the OTK - I now have 15 or so ready made. I think I’ll launch the site officially soon (and by that I mean pay Wix so I can use the URL I have, at the moment the site is just like this https://theengineeringocto.wixsite.com/website/ ). I’ll also make the Tindie page go live, and I’m thinking of putting them on eBay too - who knows, maybe someone will buy one!
The ebike is still the thing I most excited about. The 2 things that have been updated last week are the SD card and LCD. The SD is pretty basic:
I’ve added the 0Ohm resistor as jumpers, just in case I mess up the lines (my first time using SD cards, don’t want to cut traces if I don’t have too!)
And the LCD section:
Why the current mirrors you ask? Well, my logic (which is quite possibly wrong), is that if my LCD is going to be in a different place to my controller (which is likely), then I need to run the I2C lines over some short distance. Now, I’m sure that this would be fine with a simple pull up resistor, but my logic is that using a current mirror will help as the length of the lines, and the capacitance associated with it, won’t introduce an RC time constant, because there’s no R (the pull up). I’d be interested to know what you guys think on this method? I can set the current to be around 1mA, and this’ll act as a pull up resistor.
Finally, this is more for the pcb layout, but I think i’m going to design something such that the LCD section is connected to the rest of the circuit (for SW dev purposes) but snaps off, breaking the I2C lines, and then I can run cables up to the LCD when it’s fitted on the bike - but that’s a future issue.
One thing I haven’t yet figured out, is the DC link capacitors between the battery and the inverter. I know that for harsh acceleration, it’ll be good to have some energy stored in the caps, but I have no idea how to determine the capacitance (any one got any ideas?). I can blindly copy some capacitance from a chinese controller schematic (Kunteng controllers) I found online, but I’d rather know the logic behind it). I think for now, i’ll also have an ideal diode to prevent regen charging, I don’t want my battery to go on fire because of that!
For now, I need to add the connectors, and I think the schematic is mostly done. A few decoupling caps here and there and I think it’ll be good to go to layout!
Thanks for reading (if anyone’s still following!)
There is a “Build log” section of the forum and I can help move the post over there. However, that will make this post public, as only the Consulting part of the forum is semi-private. If you’re OK with that, I’m happy to help move it.
Hey Chris,
Thanks for the help - I think that’s fine to make it public, I would like to make this an open project at some point (the ebike) so I see no issues with moving it over.
Thanks very much,
Max
Great, well I have been enjoying the updates, please keep them up! Love me some 0 ohm resistors too! :slight_smile:
The current mirror idea is interesting. How far a distance do you expect the LCD to be from the rest of the circuit?
am not sure the current mirror is a good idea.
Did you check the compliance range, how far to the rail it works. Also, coming into and out of current feed, the transistor delay can be significant
A standard pull up works good due to the margin of the positive trigger with respect to the 3. 3V rail
Hey Guys!
Before the update I’ll respond to the messages from before, sorry the replies are delayed!
Chris - I don’t expect the distance to be too far, a meter at most. I know I2C can be okay at 100Khz for some longer distances, but I thought it was a neat thing to try. I’ll probably add some pull up resistor footprints, so I can compare the waveforms I get from the two methods.
kvk - I haven’t done much testing, but I did google the idea afterwards and it does seem to be a method others have used. Like I said, I think the main benefit is that you eliminate the ‘R’ value from the RC filter circuit you get, with the parasitic capacitance the wires introduce. I’ll post my findings here as to whether it makes a difference or not.
Regarding the update, the Oscilloscope tester keyrings went live about 24 hours ago, and I’ve actually already sold a couple which I’m super happy about, having never sold any electronics before! The website is now live too (www.theengineeringoctopus.co.uk) as well as the Tinde line (https://www.tindie.com/products/theengineeringoctopus/oscilloscope-tester-keyring/) . Someone also took my instagram post, and made a write up on hackster.io which I thought was pretty cool ( This Oscilloscope Tester Keyring Puts 'Scope Troubleshooting Powers in Your Pocket - Hackster.io )
Regarding my ebike project, I decided to play around and see what’s the likely voltage I’ll see when I throttle back, and the motor turns into a generator. Since I’m using the triple H bridge configuration for generating the AC waveforms for the BLDC motor, the MOSFETs internal body diode will act as a crude 6 diode rectifier. I was interested to see whether the generated voltage would be sufficent to charge the battery. I’m not (yet) interersted in harvesting this generated power, rather I want to ensure that I don’t over charge the LiFePO4 and cause a fire.
I bodge together a 3 phase rectifier, and hooked this up to a scope to see what it’s likely to be:
The generated voltage reached ~20V. The horrific spikes after the ramp is when the BLDC hub motor fell off the bench :man_facepalming:
Of course, this generated voltage is proportional to the speed, and this is a constant defined by the motor. It would be best for me to determine this constant, and then I can use it to estimate the generated voltage at a particular speed, for example the max speed of the bike. If this voltage it over the battery voltage, then charging will of course happen. I will then calculate the amount of kinetic power, and see how much electrical power is available, and therefore the available current. Hopefully this will be less than the C rating of the batteries. I believe it will be, but I think this is a good learning exercise and also a good sanity check.
That then got me thinking about how I will measure the speed, since that’s needed for determining the motors constant I mentioned above. I decided to take the BLDC’s internal hall effect sensor, and use that. It generates a pulse each time 1 of the 23 poles is over it, primarily used for commutation. This occurs every 15 degrees the wheel rotates. Therefore, I should be able to count the number of pulses in a particular amount of time (lets say, 500ms) and then get an average speed over this time.
I’m a fan of the STM32 series micros from ST. I used them at uni, and I have a dev board to hand. It’s the prime reason why I chose the STM32f0 MCU for the ebike project. I quickly through together some code (I prefer to get down to the register level and twiddle bits myself, I can’t seem to get my head around all this high level abstraction libraries for MCUs), and managed to get two interrupts going: one for the 500mS delay, and the other for counting pules of the hall effect sensor. I have a simple board with a pull up resistor (the hall effect sensors are open collector outputs) and a capacitor for low pass filtering. This goes into one of the MCUs GPIOs, and a rising edge trigger an inturpt, which increments a counter.
When the 500mS interrupt triggers, it takes the value of the counter, and converts this into MPH (by knowing the diameter of the wheel, and the fact that 23 pules = 1 full rotation, this is quite simple to calculate). I haven’t yet implemented the code for calculating the MPH, but the 2 interrupts and such I have uploaded here for anyone who’s interested - Speedo for ebike controller using hall effect sensor · GitHub
And that’s about me done! I’m now going to go finish the code and see if I can get the MPH reading done. I think I will then use the ADCs to measure the voltage generated by the motor, and divide this by the speed, and print out the motor speed constant. I’ll need to have the code written for the Ebike’s firmware anyway, so I guess it’ll be good practise!
A little later than usual, but unfortunately not a lot has changed since the last post, and I can’t imagine my schematic updates are all that riveting.
I’m now at the stage of assigning footprints to the schematic symbols, so it won’t be too long before I can start the 4 layer board, hopefully I can get the designs into JLCPCB before xmas is over, and get their 4 layer + SMT assembly deal, for something like 2$!
Attached is the current schematic, I’m going to make it available, with the board manufacturing files, code and BOM, on my site at some point, as I think it’ll be cool to make this open source. The github link is GitHub - maxsimmonds1337/EBIKE and my site is www.theengineeringoctopus.co.uk.
Let me know if there’s any glaring mistakes in the schematic!
Ebike_Controller.pdf (203.1 KB)
Nice looking schematics
Some comments, maybe Error 40 from my side:
R4 etc is 20mOhm, guess that is a typo
D1 is zener. Replace with schottky. Zeners are sloooooow, so your gate boost turn of will dripple current through the parasitic cap
R20 is not nessesary, NRST has internal pullup. Normally when using external resistor is should be of 10k or less (avoid glitches)
U2 has abs max 55V, but zener D7 is 56V type, so that won’t protect the module
U4 is is not a rail to rail opamp, so you cannot measure the stage current. Also, you need protection on that input, the motor currents can be negative
C23 is 0.47n, you need minimum 22uF for the buck converter
D8 should be schottky
DS1 datasheet is hard to find, but AFAICS LED must be supplied from 5V. So no R34 and you need to drive it higher than 3.3V. The controller also seems to be needing 5V
A side comment. BLDC has more noise than FOC. The F030 can handle 3 phase FOC with the ST motor control library, so you could remove the need for the motor controller and hall sensors. Don’t know if you have other specific reasons for BLDC control. Maybe sourcing issues
Wow, thanks @kvk! I’ve had far less thorough reviews from some companies I’ve worked at! You pointed out a few things I totally forgot to look at, and in some cases (capacitor footprints!) would have gone to copper, so thanks very much. I’ve addressed each point below:
Yep - typo :man_facepalming: a copy and paste error on my part, I’ll change that to around 5 Ohms, it’ll be a placeholder anyway, but 20m is very misleading so I’ll change that.
I think I chucked down any diode from the library - I should have spotted this is the symbol for a zenner! I was going to use something like this Buy Electronic Components Online - LCSC Electronics an SMD UF4007.
I did not know that! I guess I should have guessed by the ‘N’ prefix, assuming that’s active low, and therefore has an internal pull up? Looking in the datasheet just now, it does state it has a permanent pull up, but could I have guessed by the ‘N’ prefix?
D7 was there mainly so that the BLDC doesn’t generate a significant voltage to overcharge the battery. Let’s say that the battery is already at 55V (it’s maximum) and I’m going down a hill freewheeling, I wanted to ensure I don’t over charge the battery?
But you make a good point regarding it not saving the IC, however, the absolute max is 65V, so I think it should be okay.
U4 is is not a rail to rail opamp, so you cannot measure the stage current. Also, you need protection on that input, the motor currents can be negative. I think the MCP6c61 is a rail-to-rail opamp, though (https://ww1.microchip.com/downloads/en/DeviceDoc/20005367B.pdf). But I’m not sure what stage current is, is that an auto correct error and should be stall current?
You’re totally right about the negative current’s - I forgot entirely about that. I’ll add a schottky diode in series with the filter, to prevent any reverse current flow from the Opamp.
DOH - again, copy paste error, but I would have taken that to copper! Thanks for pointing this out. I also haven’t yet spec’d the diode, I forgot about that. So I’ll find that too.
DS1 is a placeholder for a random LCD module I have at home, but I will check that it’s 3v3 compatible, because I just assumed it would be, nice spot. The IO expander (U3) seems to be fine at 3v3.
Yeah this is totally a personal thing - I want to, at some point, write my own drivers for the F030, hence why I have the Hall effect sensors connected, but I don’t really need them for the control (since the driver will be doing that for me). But, to speed things up, I thought I’d start off with a driver. I can then probe the driver, see how it drives things, and replicate it in software at a later date, and, like you say, remove the driver and possibly the hall effect sensors if I go for FOC.
Thanks very much for the review!
If you got spare pins on your micro I would put some parallel to the SDA and SCL pin. I used it in a IIC design to get rid of the pullups resistors altogether. If you need more pullup you just change the software by make more pins pullup instead of tri-state.
you got very little headroom for the LCD backlight. I suggest you use a logic drive N-channel mosfet to avoid the Vce(on) of an NPN transistor. It also saves you the base resistor. Note that the Anode and Cathode of LCD displays are floating and normally not connected to GND or VCC. This means if you could connect them somewhere else. Personally I would have gone for a micro version with more pins. You could simplify the circuit by doing away with the bus extender and add more features like PWM the backlight and the contrast.
The voltage is too small, so a series diode won’t work
Add one accross the input, with a resistor in front. Then you divert current away from the opamp
Also, add a resistor network to offset bias the input to the opamp. Then you can actually measure negative currents
@kvk you’re, again, totally correct haha. I’ve gone for the following, what do you think?
(I don’t mind yet about measuring any negative currents, so I’ve kept it simple for the time being)
@Bikkel I agree with what you’re saying, the Vce will definatly reduce the available voltage, so, as per you suggestion, I’ve gone for a logic level FET. I kept a base resistor, just to ensure I don’t draw too much current from the IO expander, I also added a pull down to ensure it’s off when things are turning on:
Thanks a lot guys, I really appreciate it, it helps me learn a lot!
Looks good :slight_smile:
But you should change that opamp to a rail to rail one…
