Hi all!
I am an electronics enthusiast and I am looking to improve my skills to create prototypes for my ideas for embedded/IoT projects that come up to mind
Hi all!
Since december/20 I had been working on a redesign of the Siguino (Github) that is an ATMega328P based board with SigFox communication (LPWAN):
First of all, I moved the original project from Eagle to Kicad, then once trying to assembly the board I faced a lot of issues to perform this task manually, so I decided to change some things from the original project, like:
Current status:
Next steps:
I am still struggling with auto-router (freeRouting.jar) and ground plane, some GND connections are missing after importing spectra session and using DRC:
I am planning to use solder mask on the vias to avoid short circuit during manual soldering:
Nice design. Looks like the size is dictated by the battery and antenna…
You don’t say much about what the use-case is nor what the constraints are.
Questions from the peanut gallery:
I’d recommend you ditch freerouting and try manual routing using KiCAD. I used to use eagle and manually routing sucked. So I used freerouting. I thought it was amazing, except for the fact that it doesn’t understand ground planes. I moved to KiCAD recently and had a very tight board. Freerouting produced something I didn’t like, so I gave the manual routing a try. I haven’t used freerouting since… The reasons I like the manual routing are:
Good luck and lots of fun with your board!
A further thought that came to me while hand soldering some 0603’s: KiCad has regular 0603 footprints but also 0603_handsoldering footprints. Those have slightly larger pads so you have more space to put your soldering iron tip down, etc. Try those…
@tve, first of all, thank you so much for the questions that estimulated me to reflect (critical thinking) about the overall design and about PCB design and manual assembly, and the use-case for this project is to monitor assets usage (e.g. doors opening through accel monitoring) in isolated areas without cellular, or wifi coverage
Answering the questions:
I am not a antenna expert, so I just took the original Siguino design as starting point, but if a monopole antenna can present the same operational performance it is a great point for improvement/change
I did not considered this upgrade until now because of the available firmware from Siguino project and I am also more familiar with ATMega than ARM processors, the sw development is still under its capacities. It is in my plans to develop some boards with ARM.
After getting scared with Siguino original components (once I was expecting to manually solder them like LIS3DH on LGA-12), I bought more tools like the small-tipped iron, it is also in my plans to also buy a digital microscope for PCB, same as the one used by Chris in CE videos
I did not digged on the power impacts, and it led me to think that this change from LIS3DH to the break-out will negativelly impact this, but first I am trying to create an end-to-end development of this board considering the manual soldering process
Yes, I just confirmed with ProAnt application note
I did not find any requirements or instruction on ProAnt datasheet or in the SigFox module datasheet. I used a 0.6 mm track width (without a technical rationale), for reference the Siguino original project also uses 0.6 mm - revisiting the application note was good to know that the components under the antenna is a possibility and not a recommended practice, once I still have some space, I will probably move them outside the antenna keep-out area
Regarding auto-routing, I will follow your recomendation and re-design the board manually, I had been watching CE videos and as you mentioned KiCad really make it easier, like the drag key
For the footprints I am already choosing those with the _HandSoldering suffix
@tve, I am grateful for all the insights that your questions drove to me, I will be re-working these points in the following weeks, currently I am following the CE learning path to create a solid background.
There are varying opinions, but be sure to consider clip-on magnifying glasses with LED illumination. I use an optivisor with 1.3x magnification (I believe) plus “swing-in” 6x additional lens) and absolutely love it. What I love is that there is zero time lag and no focusing issues (i.e. my neck does the focusing), plus I use it in the field too, not only at my desk. To make a video or critically inspect boards a microscope is most likely best, but to hand assemble, not so sure.
I just did both introductory projects from Contextual Electronics this past weekend:
For both CE Header and Current Sink or Swim I struggled to understand and follow along through the steps and videos, I mean, to understand the project objective until the project realization, in comparison with the two projects reported above (blinky and shine) that were easy to follow, the Advanced BLE-CELL (ABC) project seems more structured and easier to follow, so I chose to follow on it… Hope to get back to both CE Header and Current Sink or Swim after ABC with more focus.
Hi all,
I designed the Siguino board Gustavo mentioned and he linked me to his blog to have a look - great to see it being used in this way!
A couple of quick comments:
All the best with the project anyway!
I did some changes from the last post to the current PCB that I ordered to be manufactured and assembled as depicted below, thanks to JLCPCB/LCSC this approach will free me up from manual soldering - probably I am traumatized by the LGA and 0402 components from original design
), I replaced the Battery Holder by a JST XH connector, also moved the antenna matching passive components from below the antenna area to outside of it to make easier for hand soldering, and removed the RTC once it is not mandatory in the current prototype.
There are a lot of improvements to be done, but I have to make the prototype works prior to invest more on this project.
I also made the XTAL1 pin accessible to support in case of ATMega328P fuse programming issues (locked out) as suggested in this blog post. This is an issue that I faced as the chip not being detected.
Note: Thank you all for the advice, I gave up the auto-routing
Hi all,
Follows an update of the Sigfox board… Just got my board from JLCPCB, and did some soldering
(all discrete components, crystal, and IC came soldered as JLCPCB service). I just soldered the Sigfox Radio, the PCB antenna, and the MPU-6150 shield.
I am having some headaches from soldering the WiSOL SFM11R2D radio…
I tried two approaches for soldering this radio. First, I put some solder in the PCB pads, then positioned the radio over the pads and heated up the pads trying to melt the solder attaching the radio with the PCB. This method presented a short from the GND pin with the Radio to the Antenna pin (top right side of the radio).
The second approach was first to put some solder in the radio pads, then positioned the radio over the PCB pads, and then heated up the PCB pads - expecting that the solder from radio pad will melt with the PCB. Still, this approach seems to not solder very well the radio over the PCB.
Unfortunately, this radio is not similar to ESP32 that provides the pad out of the PCB edges:
The WiSOL SFM11R2:
Any ideas or suggestions from the more experienced for soldering this radio are welcome (solder flux/paste will help ?) ![]()
Another operational doubt is that I used an SMD rework station to remove the radio and try soldering again… I used the airflow at about 250ºC to do that. Still, the SFM11R2 datasheet mentions that the max storage temperature is 125ºC.
What is a good temperature to use for removing components ? How much above ICs datasheet temperatures is acceptable ?
I’ve soldered things like that using paste by hot air or relow oven generally without too much issue. I think your difficuly probably comes from having cold solder on the pads to start which will prevent the module from sitting flush on the board.
It looks like you’ve brought the pads on your pcb out beyond the module which seems like a smart idea, if you have shorts you can probably clean them up by sucking some solder out with copper braid.
I’d try again after cleaning all the solder from the pads, laying down some paste, pressing the module down and either heating one pad at a time with your iron or doing the whole thing with hot air.
I’ve never actually managed to cook a part to a nonfunctional state with air, so I wouldn’t worry too much about temperature while prototyping. I do also normally use this low temp solder which helps a lot: https://www.digikey.com/en/products/detail/chip-quik-inc/SMDLTLFP/2682721
Thank you, @emolson! I will buy a solder paste to perform the soldering with hot air.
I also found a project in the hackster.io using a similar radio and using the approach that you suggested. (reference)
I had success with freerouting (auto-router). But I advice to manually route the “important” stuff, planes and so on before the magic is performed.
Just an update from my Sigfox project… I will need to redesign the board once it was very difficult to hand solder the radio
Impossible (through hand soldering) to do not short GND and the output to the Antenna:
So, I put some keep-out zone on the pins of the radio to avoid this GND issues:
Now, let’s go to another China PCB production and deliver time
(Whoops, I didn’t realize this thread was 3 years old and somehow showed up as “unread” for me.)
You should really be able to solder your first version as long as you use either hot air or a hot plate. Using leaded solder really helps thanks to the lower melting point. Also, it means that nothing on the radio PCB gets affected since it uses lead-free solder.
So put solder onto the PCB or pads, add a bit of flux, place the radio approx where it should go, then heat with air or plate. (I like to go 90% of the way with hot plate and then add a touch of air for the final melt.) Once the pads melt, gently nudge the radio with tweezers: you will see it snap back into place. Also good is to gently tap from the top on all 3 edges, this allows any pads with too little solder to make contact.
If you don’t have a temperature controlled hot plate use a cheap skillet or piece of metal on the stove and go slowly.
What I like about this approach over an oven is that it all happens in front of my eyes and I can intervene and/or tap on components to ensure they’re properly in place.
If you use paste, a trick I saw and have used since is to dilute the paste with flux (liquid or tack). Then you can paint the paste across the pads using a THT resistor lead as brush. No need to be exact. The extra flux makes it easy to paint and also ensures that everything ends up where it should when it reflows. This is what I’ve found to be easiest when doing 0.4mm pitch QFNs.
Everyone ends up finding their own special sauce to make this stuff work. The key is some patience, calm head, and experimenting!
