Hi There, I am an old member of the CE course I have an question about ESD protection, I think this is a very interesting topic and should maybe be included in CE
I recently designed a circuit for a product which is now being produced.
However, during EMI and ESD tests it failed the ESD test.
Big problem of course since I had not anticipated that. Now I am looking for what I did wrong so I can potentially fix it.
The product consists of 2 load cells both with an instrumental amplifier behind it. (AD8226)
The AD8226 is ESD protected to 1.5kV but apparently this is not sufficient and should be 8kVâŚ
If the load-cells were completely shielded from the user this was no issue, but since they are made from aluminium and in screwed to the aluminium housing⌠My guess is that the issue lies there.
Question is:
How to protect the inputs of the AD8226 from ESD without disturbing the very fine readings from the load cells (wheatstone bridge).
And should I also protect the V and GND to the load cells?
Is the use of resistors sufficient or should I use diodes? And which will do what to the circuit and protect what?
Can anyone point me in a good direction or tutorial or explain the basics to me?
And maybe someone might find it interesting to have a look at my schematic and product and tell me what to do.
Thanks in advance!
Frits Jan
