Originally published at: https://contextualelectronics.com/topic/csos-resistive-divider-cleanup-and-calculation/
How to find the second resistor that goes into the resistive dividers with the potentiometers. The proper orientation of the resistors. Commit Before Commit After
I ended up using a 1k potentiometer, because they we no more expensive than 10ks now.
I was wondering why it is so important to use a tight tolerance resistor in the voltage control section, but not for the current control section.
