Originally published at: https://contextualelectronics.com/topic/creating-a-new-library-and-footprint/
Here are some of the links used in these videos: http://www.555-timer-circuits.com/flashing-led.html https://en.wikipedia.org/wiki/555_timer_IC http://www.nxp.com/docs/en/data-sheet/ICM7555.pdf
Hey Chris, in the âCreating A New Library And Footprintâ video, I noticed at 0:48 you already have the 7555 chip in the Pcbnew viewer. I donât remember you going over how to load that or generate it in this part of Kicad. Can you go over that?
Never mind. I noticed in the next video, you went over it. I suggest switching the order of the two for clarityâs sake. Thank you. You do a fantastic job with these videos.
I can confirm that the two topics âCreating A New Library And Footprintâ and âLibrary Setup and Part Associationâ seem to be around the wrong way.
In addition, I donât seem to be able to click from the project pages to the forum links. I get 404 Error at the URL âhttps://ceforum.discoursehosting.net/session/sso?return_path=https://ceforum.discoursehosting.net/t/library-setup-and-part-association/117â
Hunh, seems like a plugin issue, since that is an odd looking link. Thanks for the heads up!
Just fixed it, thank you!
