Originally published at: https://contextualelectronics.com/topic/browsing-ltspice-on-a-vm-using-macromodels/
LTspice will be captured on a VM running Ubuntu using WINE. If you need help getting set up in Linux, please let us know in the comments. You can use Macromodels to browse the expected behavior of build in components. You cannot see “inside” the LT Modules, but the Macromodels helps make up for that.
"Your First Simulation: and “Browsing LTSpice…” appear to be the same video.
