RS-485 is a PHY. It offers literally nothing except a specification about differential signaling across some wires. You will need something to do the data framing and channel access. You can write it yourself, or find something that already exists. I recommend the later.
CSMA is better than nothing, but I recommend something with guaranteed-time-slots. Doing CSMA right takes a pretty serious contention avoidance algorithm and frame reservation implementation, and even then it maxes-out around 40% channel utilization. So just be wary of that. At 25m you can run the bus much higher than 9600. A shorter transmission period will make everything better, if you’re doing CSMA.
When you say spurs you mean stub length… which gives spurs?
I have read more on can and rs485. Still I don’t understand the difference between CAN and rs485 on a electrical level. I understand that CAN has predefined higher level. Is there a difference?
yes the length of one node away from the main bus wiring. they’re both similar electrically, the spec calls out for different abilities, rs485, more modes, greater speed and longer. but since rs485 doesn’t define any protocol the comparison ends there.
My opinion is that the firmware & software cost will be much higher than the hardware cost. If you can find a solution that has the fw and sw all completed, this is the way I would do it for a small job like this — where hw unit cost not a serious concern.
So if you can put together a CAN network that does everything you need, start with this. Change the PHY to RS-485 if you need to, but keep all the CAN SW.
FlexRay may be another option. It’s more robust than CAN, but less accessible
With the exception of the STAR bus topology (instead of a straight line) CAN is really the ideal solution for something like this because it has built in arbitration and error checking. CAN also has a very robust track record in the worst conditions.
If you run it slow, the topology probably does not matter but you run the risk of timing issues between different spokes of the network and also there is the case of where to terminate the bus given all of the spokes. There is such thing as the concept of a “CAN Hub” to connect multiple spokes and manage them but that is just added complication. Daisy chain FTW.
CAN will probably work fine, you can just drop the speed. It just wasn’t a good solution for my application, especially as we already have the RS485 and sw/fw in place. flexray is also a good option, but it is expensive, it was picked to replace CAN because of the limitations and issues with it.
it’ll be interesting to see the results of a 1000 node CAN daisychain.
Yes this is quite a lot of nodes, the downside to CAN is that each node on the network is checking the other node communications and can invoke an “error frame” as a result (and depending on how you configure your controllers) this can cause problems on a bus with a high number of devices or a bus that is not ideally structured (like a star).
I’ve personally worked on networks that have about 30-40 nodes running at 250kbaud and it was quite robust (it was the main control network for an X-Ray system). In this case we had a star and probably 100 meters of cable but in the center was a hub that was capable of managing each individual stub and taking it off of the network if it became a problem. I do not think that this system would have been nearly as easy to implement/maintain if it was done with RS485.
sure and the spec of CAN is 30 nodes, so sounds like you were in spec, so no reason it shouldn’t work. remember rs485 is just the electrical spec, CAN has the protocol too. if you’re inside the electrical limits, but outside the protocol limits you can change the protocol in rs485.
i like CAN, i use it often and have an automotive background, but i just have pause about the number of nodes, just as i did for my recent exploration about updating from RS485 on our 350-600 node current systems.
Things that would limit the ceiling of CAN nodes are:
Available Node ID’s (I think this is 11bits … 2^11=2048)
Parasitic Capacitance of CAN transceivers (seems like this would be variable based on the transceivers that you use)
Propagation delay of ACKs (more a limit of capacitance/bus length)
So much great info and thoughts. I have been searching and searching and did run in to this tutorial: http://www.computer-solutions.co.uk/info/Embedded_tutorials/can_tutorial.htm It was som what revealing on the questions you pose. And if you read the data sheet https://www.nxp.com/docs/en/data-sheet/PCA82C251.pdf it staes 110 nodes. But as LukoBeno did point out this is dependent on a number of factors but one of the most important must be speed since each node add a capacitance to the system. I will take all your suggestions and go with CAN and use some repeaters for the star nodes. I will also buffer the star nodes so that the data can be resent if no ack was recived on one leg. Also this would give the option during debugging to identify troublesome stubs and just splitt them in to two nets with a repeater in between.
CAN uses a lossless bitwise arbitration method of contention resolution; if two nodes start transmitting at the same time, the address of one of the nodes will be corrupted and that node will cease transmission. This is possible because CAN transceivers only drive the line into one state (from recessive to dominant), similar to I2C.
RS485 transceivers drive the line high and low so if two nodes start transmitting at the same time, the data from both nodes may be corrupted as the line is driven to some mid-rail value. RS485 supports 32 Unit Loads on the bus. Many transceivers are rated at 1/8 UL, which allows 256 nodes on the bus (see Texas Instruments SLLA272B - The RS-485 Design Guide).
I have used RS485 in a multi-master system in my first job, with a PIC16F877. I used a simple CSMA/CD (Carrier Sense Multiple Access with Collision Detection) scheme, where the UART interface simultaneously writes to and reads from the RS485 bus allowing byte-wise collision detection (differential drive prevents non-destructive testing). If the data was corrupted the master would cease transmission and retry after a random time. It worked OK but I only had a few masters.
LukeBeno, I agreee with you in the neat part of just smash it together in Ardruino. It’s so fast most of the time. And great tools are worth the cost. As a consultant time is money!
James. So what you say is that RS485 can be as stable as CAN with the right lib. I still leaning to CAN since I can relay on years of industry standard used in an environment where faults can = deaths.
