I’m sketching on a multi star topology to act as a control system for escape room/Space game. So I want every thing to be connected to one system and each node (with micro controller) should be allowed to send update once a user pres the button but also be told to change the color during setup to test all buttons. I also intend to drive power through the same flat cable but there will be possibilities to inject new power points injecting the power in a new point. Debugging and simplicity to fix problems is king.
My question is what is the best bus system for multi master. CAN, RS 485, LIN, other?
I intend to use star nodes which will repeat the signal to each star leg other than the one it received the message from to avoid to long stubs leading to all kind of funky with reflections.
The length of the system will be up to 25 meter but the data rate will be slow. So 9600bps will be enough. Acks will be crucial and all will be low voltage.
PoE is interesting but I would like to keep the system to only one bus type and it need to be low cost since every button will have microcontroller talking out on the bus. But maybe PoE could be an option if I have multiple roomes… hmmm.
for the number of nodes and distances it seems a good choice, where CAN , LIN etc wouldn’t be since limited nodes and distance for CAN. (also i just did this search for replacing the RS485 and i had a hard time finding something better)
watch the bus, send when its quiet, send and test the receive, ack, etc. the usual stuff
Rs485 does nothing MAC related, it’s just a PHY. You can run CAN over rs-485, which might be the best option for you. It will provide some MAC and protocol features you’d otherwise need to implement.
RS-485 is a PHY. It offers literally nothing except a specification about differential signaling across some wires. You will need something to do the data framing and channel access. You can write it yourself, or find something that already exists. I recommend the later.
CSMA is better than nothing, but I recommend something with guaranteed-time-slots. Doing CSMA right takes a pretty serious contention avoidance algorithm and frame reservation implementation, and even then it maxes-out around 40% channel utilization. So just be wary of that. At 25m you can run the bus much higher than 9600. A shorter transmission period will make everything better, if you’re doing CSMA.
When you say spurs you mean stub length… which gives spurs?
I have read more on can and rs485. Still I don’t understand the difference between CAN and rs485 on a electrical level. I understand that CAN has predefined higher level. Is there a difference?
yes the length of one node away from the main bus wiring. they’re both similar electrically, the spec calls out for different abilities, rs485, more modes, greater speed and longer. but since rs485 doesn’t define any protocol the comparison ends there.
My opinion is that the firmware & software cost will be much higher than the hardware cost. If you can find a solution that has the fw and sw all completed, this is the way I would do it for a small job like this — where hw unit cost not a serious concern.
So if you can put together a CAN network that does everything you need, start with this. Change the PHY to RS-485 if you need to, but keep all the CAN SW.
FlexRay may be another option. It’s more robust than CAN, but less accessible
With the exception of the STAR bus topology (instead of a straight line) CAN is really the ideal solution for something like this because it has built in arbitration and error checking. CAN also has a very robust track record in the worst conditions.
If you run it slow, the topology probably does not matter but you run the risk of timing issues between different spokes of the network and also there is the case of where to terminate the bus given all of the spokes. There is such thing as the concept of a “CAN Hub” to connect multiple spokes and manage them but that is just added complication. Daisy chain FTW.
CAN will probably work fine, you can just drop the speed. It just wasn’t a good solution for my application, especially as we already have the RS485 and sw/fw in place. flexray is also a good option, but it is expensive, it was picked to replace CAN because of the limitations and issues with it.
it’ll be interesting to see the results of a 1000 node CAN daisychain.
