Best Dif analog logic analyzer?
Hi!
I’m using Salea logic 8 pro it’s great but need something similar size as it’s dropped inside a robot but as I have multiple CAN busses at 1Mhz I need multiple DIF measurements. And orsiloscope standard size is way too big. About salea or about 3 times bigger max.
Any suggestions?
Use sigrok’s pulse view with any of the supported hardware
Ken Tindell’s setup below.
But that is the question. What good dif measurement hardware exist for multiple channels 50Mhz+ which also can do logic analysis. The can is completely free floating I tried using the system ground but it did not work…
Take a look at this one
Diff inputs, high rate, CAN
Another
Thank you! But those don’t look like analog and digital. I need to see signal integrity as it’s a noisy system and many devices on the buss.
