The inlayed monitor is a nice touch. Cool. I like the “quick draw” hot air clasp idea.
everyone seems to have such neat benches, all lots of interesting stuff. mine looks like a bomb hit it and then a bunch of messy people looking for something they couldn’t find it passed through.
i did just start using the ikea cube type storage recently and that is helping, though there is basically no hope for me otherwise, switching from 2d working to 3d is basically all i have left.
my neighbours think we’re nuts.
Wow. I think that makeblock beam idea is what I’ve been searching for. Do you just buy them piece by piece, or could you recommend a starter kit?
My bench is neat right now, but normally looks like a bomb exploded. It’s neat due to work for a client involving HV stuff, so no room for errors
My storage is reasonable sorted, but not perfect. I keep stuff I gathered 10 years ago, thinking I would need it some day. I got a lot of 600V 30mohm FETs that is super expensive from a former employment where they just threw it out. One day I will maybe make a super efficient offline SMPS and get to use them…
In 6 months I will be moving to a new house and will get a lab designed for my work. So instead of 6 square meters, I get 20 square meters, so I will be drawing up the perfect combination of PC work station, soldering and lab bench, CNC bench and storage
Mine would look terrible if it wasn’t for the lectures that force me to clean up. I could post a picture of the one at my office, as that’s quite messy
@rclott I’ve bought most of my Makeblock parts many years ago when they had a working webshop with lots of parts. These days, they’ve reduced the scope of the product to only be kits for kids. It used to be more than 400 parts including pneumatics, chain drives and much more, but now you can only get those basic kits. Due to that, I don’t think I can recommend Makeblock any more? It used to be fantastic, but they didn’t quite understand that they were sitting on a gold mine. It’s the perfect solution for STE(A)M activities in schools.
Now I’d maybe just use 20x20 aluminium extrusions? It’s cheaper and currently has more parts. https://ooznest.co.uk has a good selection. They’re in the UK, but you can find the same parts at Misumi and other vendors.
yeah i started off with good intentions and the things just spiraled people told me to plan out ahead of time and 3d model it up. it is good advice if you already have the gear or know what you’re going to get but mines just evolved over time. luckily my partner has been good at keeping me out of the house so i only infected one room outside the workshop, and the little summer room out back heh. but yeah looking around me its overwhelming chaos, i spent a couple of days cleaning up last week and you wouldn’t know
i should share a picture of it as a cautionary tale.
My bench is never clean. I sometimes go on a cleaning bender but you would never know from looking at it! I am toying with the idea of putting my scope, power supply, lab PC/Monitor/KBD and tool set on swing arms so they can be moved in and out as needed. The idea is to lift them up and leave the bench space clear for the project at hand. They all take up too much space as it is
Here is my bench:
General equipment:
Amscope trinocular microscope
2 Pace ST50 Soldering irons
Hot air and wand board heater
I am working on my part placement tools and techniques with the vacuum pump on the bench as a gradual enhancement of my assembly capability.
DVMs: two 2.5 digit meters and a clamp-on ammeter DVM. All low-end models. They are sufficient for my needs.
Three variable power supplies, two with digital readouts. Including some home build supplies, 11 outputs.
Test equipment:
Rigol MSO1104 100 MHz mixed signal scope. --=meets all my needs
Rigol DSA832E 3GHz spectrum analyzer.
Nano-VNA 3 GHz model
WindFreaks USB 6 GHz signal source
Slowing growing collection of low-cost antennas for radiated measurements
The latest addition is the small DIY Faraday cage in the upper right. Significant workshop reorganization was required to make space for it. This necessitated the purchase of a rolling tool chest for storage.
My whole workshop is 8x9 feet with an adjacent 3-foot walkway to the garage. The walkway must be kept clear! I also have access to the garage for radiated signal measurements when my wife’s car is not in the garage.
Cleanup occurs when critical mess is reached. – That is a fuzzy combination of state of disarray, current project needs and my mental state at the time!
Interesting. Are you using that for radiated measurements?
I have looked into TEM cells, they can actually be bought for quite low funds now:
Lately I bought a LISN and a Siglent spectrum analyzer, so I can do conducted emission measurements. I would like to add radiated measurements to that capability also
I have this antenna, but have not verified the setup:
Kalus,
I use it for radiated work above 900 MHz. I have done radiated immunity and wire induced immunity testing at lower frequencies. It is also great for RF measurements to test radio sensitivity.
TEM cells have an upper frequency limit based on the dimensions. If you are handy and creative, you can build one yourself. Or, if you have access to a sheet metal shop. You can build it from galvanized heating duct materials. This article is pretty good. untitled (chaosproject.com)
I am contemplating a LISN. I built one a long time back. – WARNING, Always use an attenuator between the LISN and your spectrum analyzer as well as not switching things while the analyzer is connected. The spikes will blow out the front end of the spectrum analyzer. I worked with guys that did it twice!
I have a couple of similar antennas from Printed Circuit Board Antennas| Commercial and Hobby Antennas (wa5vjb.com). They work pretty well. That one should also.
It can be expensive. A collegaue of mine tested a converter without a filter, and blew the testreceiver. That was only a 50.000 USD dollar mistake
I am going to build thios protection circuit:
It’s just a high pass filter
The problem with conducted emissions measurements for me is the logistics of setting up a ground plane. I can do it and have done it, but it’s a PITA.
Often conducted emissions problem areas are from 150kHz to 5MHz, and in that range a big ground plane is not that important. Next time you do the measurements, try to keep the strap and lift the DUT away from the ground plane
On parts storage, I do sometimes spend up to 30minutes to find a part
Anyone dine this: take hires pictures of all the parts, let some AI SW do text recognition, so next time I need a part I can search for it in a database and the picture ID will show where the part is?
I would not be comfortable with that as my protection. The capacitor is a low impedance for transients. I always use a 10 dB attenuator. , – a $15 10 dB sma pad would work. You just have to calibrate it out in the measurements. There is usually enough noise floor margin on a spectrum analyzer.
Many commercial LISNs have limiters.
Yup. Lots of mesh from the hardware store or aluminum foil.
There are a lot of times when you can get away with out it of make something very small and crude for prescan work. You do need it for the certification tests. It really depends on the DUT and the particular test. You have to do it for a while to figure it out.
A ground plane is essential for accurate CE measurements in my experience and understanding of the test setup,. The measurement is highly dependent on capacitive coupling between the EUT and the plane (why line cord length and positioning have such a big effect on the measurement). The GP doesn’t have to be “big”, but it should be a few multiples of the EUT dimensions and it must be the specified distance from the EUT. The GP is usually horizontal in commercial test labs, but it can be vertical, which may be easier in a DIY setup.
Not all parts are labeled with identifying information. Sometimes just a date code on things like SOTs and SMD caps usually have nothing on them at all.
The real trick is to be diligent about keeping your parts organized.
For my surface mount parts, I have them in a set of books with vinyl inserts that I can slide the tape into. I have 5 6-ring notebooks - typically a page is for one kind of part (805 resistors, for example) and all the similar pages are in one book so finding the right part is pretty quick.
My loose parts (a few big SMDs and all TH parts) are stored in small parts bins and labeled. I have to say, that isn’t as easy as with the SMD books.
I keep a database of all my parts and try to update it when I use them. But, I’m not as good at that. So when I run out, of something, I put it in a disti shopping cart. I generally have a number of things in a mouser or LCSC shopping cart. They don’t auto empty them due to inactivity so when I actually place an order it picks up my needed items. A recent example, I use a lot of BSS138s. I noticed I was down to just a couple so I added 50 to my LCSC shopping cart. Next time I order from them, the BSS138s will be there.
I forgot about the vertical approach! Until recently, I always had more than ample lab space. My DUT’s were always well less than half a cubic foot and plastic-encased. There was very little capacitance to ground. The emissions were differential mode and there was a wall-wart. 10-20 dB margins were always easy to get. So, there was lots of margin going into the real test. That being said, the certified site I built and ran did meet the ANSI specifications.
