Thanks, Cyber City Circuits don’t seem to have an online instant quote and their assembly page talks a lot about JLCPCB so it isn’t totally clear if they actually manufacture in the US or just outsource to China?
I’ve been reading some bad reviews of Aislers on EEVblog and while it is hard to find the information on their website, I think they outsource to unnamed “local partners” for production in the USA as they don’t have any facilities there?
Have you considered Circuithub? They are based in Massachusetts and the entire process is automated. You upload the design files, BoM, fix problems in the part numbers, take a look at the gerbers and place the order.
They will raise an issue through their web dashboard if they see a problem. They also give you varied pricing based on when you want the order to ship.
Thanks, they look really good. The prices are a bit of a shock after being used to Chinese bargains! around $50/board with assembly (excluding components cost) compared to under $3/board. But if that is what my customer requires…
The two highest tech, most automated ones that I’ve run across are Macrofab and Circuithub. Circuithub is based in MA, as stated above, and is partnered with Worthington Assembly which can handle anything somewhat more custom than what the Circuithub interface can handle. Circuithub has a fantastic podcast hosted by their CTO Chris Denney which talks about the nuts and bolts of what happens in an CM and really stays focused the topic of the CM business and what goes on behind the scenes. It should be required listening from the beginning for new engineers (and experienced too!). Macrofab also has an excellent podcast, but it’s a more traditional two guys yapping at each other format.
At one point I think Aisler was trying to assemble in the USA, but not sure they ever got there.
Not necessarily recommendations, but you might also want to check out Tempo Automation, Advanced Assembly, and Advanced Circuits.
Thanks, they look interesting. Disappointing that you have to create an account just to get a quote, and have to upload your private EDA files, not just GERBERs, CPL+BOM They share your private files to the Amazon Cloud and it does seem like they set up their site to build a ‘community’?
You’re probably not going to find a place that doesn’t touch an S3 bucket or similar that also has online upload, that’s pretty much the norm for anything that has a “modern” experience.
Both Macrofab and Circluithub use the design files so they can extract things like xy data more reliably, and allow you to verify orientation and placement of parts online.
Until last year, I worked for the company that owns Screaming Circuits (doing EE work) and I worked with SC closely. I never had to deal with external pricing - only internal number shuffling. So, I can’t comment on that.
What I can say is that it wasn’t my first rodeo and I found their processes, attention to detail, results and communication to consistently be impressive. My last design with them was packed with 0.4mm pitch BGAs and speck of dust-sized parts - all with zero defects.
I can’t give names, but I can assure you that the client list is a who’s who of household, high-tech names with demanding requirements. And not just test fixtures or whatnot - I’m talking about boards that are currently in orbit.
I’ve worked with MacroFab as well. For the right person/project, where a very hands-off process is desired - basically JLC style - they seem to do a good job.
The people I’ve dealt with have been nice and helpful. Still, I found the overall process to be, for lack of a better word, quirky or maybe not yet refined. So, I definitely experienced hiccups.
That said, if what you’re doing is pretty mainstream (common parts, common stack up, etc.), it may well be smooth sailing. So, I’d still recommend including them in your list of opinions to consider.
There are a lot of smaller more local ones. I’ve been using Technotronix in Anaheim, CA, when I need someone local. A client in Chicago had me use United Innovative Solutions in Elk Grove Village, IL.
These smaller shops will cost much more than Chinese shops and their quotations are manual, but they tend to come in at prices better than the big automated US-based ones, which are far more expensive in my experience.
One nice thing about working with local shops – they appreciate you as a customer more and sometimes do little favors (like an emergency rework, letting me inspect a suspect board with their X-ray, do a same-hour turn).
The reality is that most established shops will do most jobs well, but will occasionally have hiccups with something new/unfamiliar in their process, or due to change in staffing causing loss of experience.
(Aside: at each CNY, reset your expectations on board fab and assembly from the previous year, as there sometimes is a large shift as they churn people, either returning back to their home village, move to a new employer, or even setting up a new competing shop!)
Good to know… it also did feel like they played some games with their day counting, e.g. reviewing boards in the middle of the night and then pushing it a day when I didn’t respond til 7:30AM.
I can’t speak to Screaming Circuits specifically or how they handle PCBs, but it’s very common practice for American PCB manufacturers to utilize third party engineering and cam review services in India to do the first pass on getting designs to a manufactureable state. A large chunk of the PCB houses in the US tend to have Indian ownership or close ties to India so there seems to be a lot of timezone correlation for some of the busywork bits over there…
Another vote for screaming circuits. I’ve had about a dozen projects done with them. There was some trouble with large QFN packages but they deeply discounted the order and fixed them quickly when I brought the issue up. Highly recommend!
We’ve been using Technotronix for years, and they’ve only been getting better year over year. Not automated, but a quick email to Ken might honestly be lower time commitment than an automated system.
My team has also been using Circuithub extensively last couple years or so and have gotten good prices, lower than most but higher than Technotronix.
+1 to this. Local shops seem to all still be in the “email files around and then email quotes and POs around” work flow, but the trade off is that they generally care abut your business. Or at least, you can get a direct feel for whether they want to do your complexity / quantity… email seems antiquated, but I also don’t like working with shops that deign to do my job. Once you get a good contact point, your next orders tend to go much more quickly.
If you need to make sure that not only is the work being done in the USA, but the design files aren’t leaving the borders, you can look for assemblers that support ITAR jobs. But, this also works if you just want to ensure all of the work is being done in the USA.
I’m in the SF Bay Area.
Bay Area Circuits, mostly automated quoting (but assembly still goes through a DFM / human pass), pricier than others but board and assembly quality has been consistently high. Lots of stackup options and materials.
Green Circuits, OK work (an occasional issue like wrong polarities), they can hussle if you need to pay for hussle. Quoting has been quite slow recently however. They are willing to handle oddball mixed assembly that require jigs and such.
Sonic Manufacturing Technologies, a little slow on the quoting (~ 1 week), but good prices and their work has been good including fine pitch BGAs on boards with blind/buried/filled vias etc.
I’ve consistently heard good things about Screaming Circuits but haven’t tried them yet (their quotes have always just been a little higher than my local shops)
Any recommendations for companies based in Texas? Smaller shops are OK as I’d like to give my customer a range of options, and I’ve already been given some good “large, automate-everything” sites.
I know MacroFab HQ is in Texas, but their “network of factories” appears to be Mexico and China?
Most assembly houses do not fabricate their own boards – they will outsource that to a PCB fab house. Depending on customer preference or pricing, it might be done in the US or sent out to China.
As @ToyBuilder said, it’s common for CMs to source their PCBs from overseas. Very few fab their own boards. Some let you consign your own boards (as mentioned by @coflynn with Bittele). If you don’t want your supply chain touching China, there are many good board-houses in Taiwan. @gregdavill has used Multech and can speak to his experiences there. When I was working for a large multinational, one of our board houses was WUS. I got many HDI boards from there and the quality was superb. A local Canadian CM I’ve worked with got their boards from JunBon and the quality was pretty good, no issues I ran into.
Personally, I want to give Multech a shot in the future.
