FreeCAD (free cost, not cloud, open source) - powerful but lacks UI polish of many paid-for/closed CAD packages. Very much worth persevering with IMHO. Includes tools for CAM and CFD, with python scripting interface for customisation if you want.
OpenSCAD (free cost, not cloud, open source) - sometimes preferred for parametrics and those more comfortable with programming than CAD.
Alibre CAD (paid-for, not cloud, closed source). One of the more popular options when Fusion 360 and Onshape’s licence tweaks get too much to bear for people.
Fusion 360 (free for many, cloud-based, closed source)
Onshape (free for many, cloud-based, closed source)
Other useful links:
To start with, I’ll just leave this link to the enclosure tag on Hackaday.com where there is a wide range of examples featured.
Here’s a NASA resource on electrical isolation and chassis grounding.
Computer Aided Machining (CAM) Tools
As mentioned, FreeCAD has the Path workbench for CAM.
laser.cut is a cool looking openSCAD plugin that can handle other subtractive processes such as CNC routing.
I don’t plan to list every slicer out there for 3D printers but kiri:moto stands out for running solely in your browser (but on your local machine - it’s definitely not cloud) and supporting fdm, laser and cnc routers.
Design Tips
For air flow, whether forced (by e.g. a fan) or natural ventilation is always improved by larger slots/holes. Realistically, when you don’t want screws/fingers etc getting into an enclosure you need too keep sizes down. @kvk recommends going no smaller than 1mm slot width. But go bigger if you can and you have heat to deal with!
For considerations I think it is worth noting RF requirements. Often this precludes the use of metal enclosures when using internal antennas, where because of their environment, they would be best suited. It may be also worth mentioning potting as a form of enclosure.
EMI is an important issue to deal with and good reason for a metal/faraday enclosure. Either external EMI like in a machine environment or in the case of radio gear where secondary frequencies/harmonics/etc need to be blocked from getting out.
Also, let us not forget aesthetics. Even for a CNC machine in my shop, I want my electronics case to look good and professional.
A build technique you left off is sheet metal bending. F360 has a really nice sheet metal module that makes it super easy to make cases and, for homebrewers, a brake is pretty easy to build.
[opinion alert] On the subject of PCB as case material. While I know people do it, it makes for a terrible enclosure. Sharp edges and poor fit are pretty common. It think it has a terribly unprofessional look to it. Several Open Builds products are like that. I have seen it used for a faceplate where the edges are recessed and it looks good.
I have never had the need for a Faraday cage. Solving the EMI at the source is cheaper. Granted, you might have a special circumstance, I don’t know. My designs has included VF drives with high dV/dt and we have never had the need for shielding
If you use Metal enclosure, and have mains in, then you need to comply to bond wire testing and touch current etc
About enclosures, if you have openings for cooling, rule of thumb is that slots needs to be wider than 1mm for reasonable air flow
A common enclosure design scheme in aerospace and other harsh industrial environments is the “bathtub” with a flat sheet lid. The bathtub has openings on the “bottom” (bathtub orientation) where bulkhead connectors are mated. A flat lid is attached over the bathtub and that becomes the “bottom plate” that is thermally / electrically coupled to the chassis. PCBAs tend to look like this example from soeffects.com:
FreeCAD is great for enclosure, bracket, and heat frame designs IMO. The learning curve is steep and the first few times I tried it, I wasn’t convinced it was any good at all (but it’s really good). It also has a decent sheet metal plugin which I’ve used to design various U-shaped enclosures. Nearly every action you take in FreeCAD shows up in the python console as something you can then take and script. It’s a good way to start collecting scripts to programmatically/parametrically duplicate an enclosure design with different dimensions.
We are currently working on a project that has 28 CCTV cameras. The customer was unhappy with the $15 grey plastic junction boxes for the ethernet termination at the camera and insisted we come up with a better looking solution. So we quoted stainless steel junction boxes, that due to the environment they were in, had to be the fancy stainless steel (316), not the ordinary (304) stainless. Each junction box now cost $300 (excluding glands and fittings). The customer agreed that they were a better looking solution and signed off on it. It must be nice to have money
If the client is spending a good chunk of money on NRE and the first run, finding a way to make the end result look good even if you/we/me have to absorb some of those costs means the client has something that looks the part, reflects their investment in the techy bit and acts as a calling card for our next project.
We live in the Apple design world now. People have “stuff” made that they don’t really understand and many of the people that they show it to may not understand, but hopefully they understand what it does and as Apicius said “the first taste is always with the eyes”.
It would be useful if we could share our low-cost looking-good techniques.
You missed my total nightmare “component”, one that has been plaguing at least one project with very small batch sizes for months:
“The Window”
I have projects with small LCD status displays. Having them mounted nicely but behind at least one piece of transparent material to stop people poking the display with a finger, biro, screwdriver etc etc has been an ongoing nightmare.
Cutting the case and getting a window to fit nicely - meh. Please tell me someone knows how to do this.
@nmcc, do you have an example of what you’re trying to build?
For me, even something seemingly simple as lining up a LCD comes out better when everything is dimensioned and parts are made/cut by machine. Getting comfortable with 3D and 2D CAD has been critical for me to do enclosure work.
If you want to do the enclosure yourself, a 3D printed cover plate (with holes for displays, lights, and connectors) with a clamshell housing is probably the easiest way to go.
No display, but here’s an example of a project I did with an inexpensive snap-together box from https://www.budind.com (PC-11476) and a paper + laminate coverlay that I did with a Silhouette machine. In this particular case, I CNC’d the openings in the front cover piece, as it wasn’t a straight plate:
I make liberal use of Hammond enclosures, as they have a small minimum qty (normally 25) and cost for custom versions (custom = CNC’d) is pretty similar to off-the-shelf. If you have a mill it’s even better because you can do the customizations yourself at prototype phase:
Or use a 3D printer for the end panels. I’ve even 3D printed a full “belly plate”, but here is for example the end plate detail (the ‘belly plate’ on that is also 3D printed):
Using this has given me basically 100% success on the test CNC item Hammond sends back.
If you combine the CNCd cases with laminated vinyl labels (I use a local print shop, but previous threads have good links like ‘Maverick Labels’ that might be more suitable in USA) you basically end up with something that looks as good as “real” test equipment in most cases IMO.
I’ve used a laminated paper label with a cutout (in the paper) for the window. This was just a one-off, but I assume you could get a self-adhesive label printed with a clear section for the window. I guess it depends how “poke resistant” it needs to be!
Sorry guys, I think that’s only visible on the consultants’ side of the forum. You could ask the the OP to change its category but bearing in mind people may have answered in context of the limited audience it may not be the kindest thing to do. We can extract links into a post on this thread (I’ll try later once I’m on my PC).
Just now circled back to this topic. I’ve been playing around with laser etching powder coated metal plates. Pretty amazing stuff. Took me some time to really dial in the process and I am still working on multicolor but I am very happy with the results. The photo is of a 4 mm aluminum panel cut on a CNC machine, powder coated with the semi-gloss black and then etched with a 40W CO2 laser. Note - 4mm because I happened to have it. Much thinner would work. A bit more detail is in my blog on the topic.
that looks good. i’m looking forward to doing some laser cut metal panels and anodising at home for panels as well. but powder coating seems a lot less of a hassle and still nice finish, great work.
I have thought about anodizing over the years but the acid and mess of it always dissuaded me. Powder coating is so easy and almost no clean up (compressed air to blow the excess dust out the door). Plus, it is a lot tougher than an anodized finish. I can barely make a mark in it with a screw driver.
yeah that’s what i’m thinking too, anodising is such a mess, i just like the colours ! we can do some of that with the laser but also silly hard to control
i just hadn’t really considered doing powdercoating at home either
