Hey Bradley, welcome! Really excited to see what you build. Looks like you have a great base to start from.
Have you started reading Ultralearning yet? I am curious about your thoughts and how that could apply to CE. One element I’d like to incorporate is the idea of “drills”, so I have been brainstorming that some more.
Yes, I have. In my case, I have the audible version of the book. Just finished up chapter 3. A couple of the biggest take away is to get uncomfortable and to seek feedback. Asking myself what really makes me uncomfortable. I’m sure like many, it’s engaging in conversation haha. I’ve been a lurker on forums for many years never one to engage in anything. Sometimes I would start to write something but to then stop midway to then drop it due to fear of maybe not understand something when it should have been a perfect time to ask. As Shia Labeouf once said - JUST DO IT!
I’m not sure what it was like in the very early stages of this website but to me, it seems you already been applying these principles from the very beginning that the book speaks about.
Love to know more about your idea of drills.
My drills of attack right
Get uncomfortable. Try my best to be engaging in the build log and provide feedback.
Learn more about DCDC buck converters. How to select an inductor for a given converter. I’ve always played around with regulators but never tried to build a buck converter. So my project is just a simple dc-dc converter and you know if I mess up somewhere I have a place to talk about it
Learn Kicad. I’ve been using CircuitStuidos for some time but there are some issues.
Yep, That’s a great one to remember. I find whenever I am avoiding writing code or doing something with RF (my two current learning vectors), it’s because I afraid of looking stupid and/or having to put in the work.
I’m currently in the direction of building modules to help create reusable designs for future projects. I saw a lot of stuff relating to EMI in DCDC converts. For something like this project should it matter? Like to know whats everyone’s thoughts are.
The other day I was thinking it would be cool if I could design something for our horses. Something like filling up the water buckets until said level and control it through my phone lol
You know at 2uA, there are probably a few photons coming out…but yeah, you’d need to start building photomultipliers to detect them
Great looking design! And I like that you are building up the reusable modules.
As for EMI, the biggest sources are going to be from not having a tight “loop” between the switch pins on the chip and the inductor. If you’re following the recommended layout, you’ll probably solve 80% of the problems. After that it will come down to the inductor shielding (if present) and any other place where current can’t get to where it wants to go.
Thank you for everyone’s input! Gave me some thoughts to research on.
Good to know Chris! Felt like I reread the datasheet a bunch of times to make sure everything was good and eval board user guide really helped out as well.
My whole BOM is built around Digikey at the moment. I figure I would get a few of them made over at JLCPCB, solder them up here then see how they play.
The Inductor of choice is SRN5020TA-120M. Since its 600mA Max circuit and 1.4A rated inductor which to me should be no problem but when I was playing around on TI Webench I notice it allowing me to pick an inductor with current ranging all the way up to +4A ex. MSS1038-123MLB. Also notice that DCR was a lot lower with coils with higher current ratings.
So really what’s stopping me from choosing something like that aside from cost and size?
As far as test equipment goes, I lean towards the microcontroller world and been playing with the stm32 Nucleo board. I currently only have DMM, bench power supply, soldering station, and hot air station. An oscilloscope and or logic analyzer is on my radar but likes to know what you guys recommend or add to the list of must-have.
For RF related stuff, A guy I work with is huge into RF and has a ham radio license and as interesting as it sounds when he talks to me about it, it goes over my head or smoke comes out of my ears haha.
Sure, you can use the bigger inductor. Penalty is cost and size as you wrote
Benefit is better efficiency, lower loss, lower thermal hot spots
For a bigger core, the flux density falls. Losses is about B uplifted to 1.7, so lower B field, a lot lower losses. Losses can be calculated from here:
Hello everyone! Wanted to provide an update on my first dcdc module. It works!
When I placed my order with JLCPCB provide my Gerber and stencil to be 39x39mm. The very next day, I received an email that the audit failed and examples to me I’m missing the NC drill files in the Gerber. Fair enough and fixed that right away.
Good idea on the tin snips! I always try to just use the entire thing and I get alignment issues. Then again, I have cut myself on stainless steel stencils (nasty slices) that I’m pretty careful around them in general.
Board looks great! I am curious about the iron as well
What you guys didn’t see is when I first upset the iron, it tipped over and the board fell into the carpet haha. To my surprise, all the 0402 components were still on the board!! Few books later, I made the support for the iron. Definitely need a vise for this lol.
I guess I can say I reflowed the board base on “feel” started at the lowest temp and slowly ramping it up with the clothes iron then got my hot air gun set to 230c @ lowest airflow. Didn’t want anything flying off haha. For next time, recently bought a temp probe to get a better idea of what the temps are when I’m reflowing the next board.
In the past, I’ve reworked many SMT boards with hot air guns as well as bottom plate heater. Reading a datasheet that talks about the reworking process really helped me understand the process and seeing how manufacturers do it. When I first started out, it was trial by fire! I’ve burnt a lot of stuff by testing it on with E-scrap we had laying around. All in all, I learned a lot by just jumping in, and who doesn’t like the smell of a burnt PCB once in a while lol.
The iron idea is excellent. I might have to try that. I’m sure there’s an iron around here somewhere, and I’m sure no-one would mind if I used it for reflowing some boards…
Can you remember what it was that you read about SMT rework that was so useful?
I remember first seeing it in a manual that came with this BGA rework machine. Spoke about temperature profiles, how to set them up, and showed a profile chart.
We mostly could get by with air gun and or heat plate but when we needed to remove something complex without pulling pads to the BGA machine. Oh I tried for laughs to remove a processor with 529 pins on 8 layer board. 400c @ max airflow and 5ish minutes later. It was not the best let’s just say lol.
As far I’m aware, many manufacturers follow IPC-7530 standard when it goes through SMT assembly.
Hope everyone has been enjoying the holidays and staying safe out there. Just wanted to pop in and share a wip project. In a nutshell, it locks a door. There is a mainboard behind the scenes that will talk to this device via RS485. Here the top-level of the project so far.
