I love you how you think! Those are all great ideas and he would love them. I think I can do several of them with what I had in mind so far, I ordered a strip of RGB LEDs for the front Larson scanner and might as well use the whole strip around the car for effects and I’ve got an Adafruit Sound FX board I was going to put in, just need to figure out amplification, etc.
I whipped up a Buck Converter Circuit (not sure if that’s the right terminology) based on the Power Swap course to Buck the 12V down to 5V for the LEDs and 3.3V for the micro (once again, thanks @ChrisGammell!) so if those end up working I’ll be able to do lots of lights and sounds easily.
Fry’s electronics has several ‘kit’ projects including audio amplifiers of various sizes, probably higher power LED drivers for when you want to really make something bright.
I am not sure which sound effects board you have now. Adafruit has a 16MB onboard storage stereo sound effects board with 8 different input pins and built in 2 channel, 2 watts per channel stereo amplifier that you can connect speakers directly to. You will have to create the audio files on your PC, possibly compress them with OGG Vorbis, transfer to the card by USB. If you go all out on sound effects, you might want two boards! The second probably does not need the amplifier built in. Currently $20 for 8 sounds without amp and $25 for 8 sounds with amp.
They also have a 24 channel PWM card for $15 that is controled by SPI that will run standard LED currents ~20ma, but you can stack them up to 30V to run 10 or 20 per channel, and the outputs are constant current so you won’t need a current limiter resistor. With their superbright white LEDs (25 for $8) with 3.0V forward bias you could put as many as 9 or 10 in series off a 30V supply and the 18mA used would be well within the PWM channel’s capability. Plus RGB LED strip lights that either go all together or in sequence, plus RGB LED circles, electroluminescant strips you can have a lot of fun sprucing it up, especially at night!
And for the tracking where he has gone, 433Mhz breakout card is a 433Mhz transmitter with a rang of up to 8,000m! Add a gps module to provide the location and have the trasmitter ping every few minutes.
Or get a gsm/gprs/gps shield $16 which combines a gps to get position and a cell phone based digital network to send the data (and send data back, like connecting to the sound effects board to make a one way radio!) so that you can find him not matter how far away he goes.
I’m jealous of your access to Fry’s, that looks like a cool place but we don’t have them up here. I’ll have to try to find one the next time I’m in the U.S.
Woah, that’s crazy… I doubt he’d make it that far on the battery (especially with all the extra stuff we’re adding). I have a cheap 433MHz radio thing from China I picked up on ebay a while back, I should experiment with that while I’m waiting for my deliveries.
That is what I will do for the headlight LEDs, but for the strip of APA102 datasheet RGB LEDs I will need to provide 5V
I hadn’t thought of that, I was just looking at a few ICs that would do it, but that might be an interesting challenge, I’ll have to look into that!
Not yet, it has been shipped by OSH Park but has stalled for a couple days at the border, I wonder what they think it is. Hopefully I get it by the end of the week.
Spray painted all the parts about a month ago but haven’t really done anything with it since due to end of school activities, summer trips and rainy days.
In the mean time the slow boat from China has started to bring me some of the things I ordered so now the fun stuff begins. I haven’t received my RGB LEDs yet, but I did get some other single colour LED strips (white, blue and green) and an EL strip to experiment with the lighting.
I also got this neat little FM/MP3 player that I thought would be a useful modification, frozen banana for scale (didn’t have a fresh one handy). I’m amazed by this little thing, it can read and decode MP3s off of a USB stick or microSD, tune FM radio, drive a display and has an infrared sensor for a remote control all for $3!
The board doesn’t look overly complicated, I’ve been able to identify the two smaller chips on the board as the EEPROM and FM tuner but I haven’t been able to find anything out about what must be the microcontroller. It is labelled as BCH5Y0Y.1 1638UDZ, but that doesn’t bring up anything useful in a search, anyone have an idea of what it might be?
I looked into this, but it seems a little advanced for me, I’m still not sure how many watts I need for a stereo and how many for a horn so I’ll have to do some experimentation. Once I know what I need I might be able to find something that would work, but I don’t think I’d be able to figure out if it is efficient or be able to improve it if it wasn’t.
In the mean time, I’ve got a 3W amplifier circuit I found on ebay and I’m working on a 15W version based on an app note
I find it curious the way they’ve separated out how the left and right are connected to power and ground, does this indicate that they should be physically separated somehow? or just showing what those capacitors are there for?
I captured it in a similar way on my schematic, but I realize during layout that it’s not going to make a difference. I’m thinking that there is something to this that I’m just supposed to know, but don’t.
The capacitors should be near a physical port for local decoupling. The capacitors act as a “charge bank” for that pin, which will likely need ready access to current when it’s quickly switching the FETs on and off (as happens in a class D amplifier)
I tried hooking up the mp3 player to the 3W amplifier board that I had and I was surprised by how loud it was, it was only pulling 10mA so definitely not 3W of power, but I don’t know if that’s what I should expect. It seems like 3W is loud enough for the speakers, but I’ll have to see if they still seem loud when it’s outside during the day competing with all the other sounds.
